tach
Discussion in 'Engine/Drivetrain' started by yotalayinlow, Oct 31, 2011.
  1. yotalayinlow
    yotalayinlow Member
    arkansas
    88 pickup
    how do i hook up my sunpro tach to a 22r?
  2. 22R88
    22R88 Veteran
    South Louisiana
    1988 Reg Cab Deluxe RN50
    Green wire goes to the coil, I crimped a spade connector on the wire and shoved it into the service connector that has the green boot cover on it, I made a small hole in the boot for the wire to pass through. The white wire goes to anything that is 12v with the key on for backlight illumination, the red goes to the 12v power and the black is ground if I remember correct. I would go to Sunpro® and download your manual just to verify. Best of luck.
    Here is a link to mine
    http://www.toyotaminis.com/forum/in.../sr5-gauge-cluster-improvised-truthful-11024/
    Later,
    22R88
  3. yotalayinlow
    yotalayinlow Member
    arkansas
    88 pickup
    ok thanks bro
