tach swap into a 89-95 hilux?
Discussion in 'Interior/Electronics' started by sitnlow4life, Aug 18, 2009.
  1. sitnlow4life
    sitnlow4life Enthusiast
    Detroit
    92 Std Cab 2.4L
    Anyone know how to swap the cluster from a 89-95 to one with a tach?
    I have the cluster already
    Thanks
  2. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    do a search you'll find tons of info..check on yotatech.com too
  3. JamesD
    JamesD Veteran
    NY
    93 Reg cab
    It is fairly simple. You need to buy an oil sending unit that is for a gauge otherwise you will burn out the oil gauge if you do not change it after the swap. Also you can adjust the tach for a 4 cylinder engine. Their is a small adjustment screw in the back of these tachs. Do a search on Yotatech on SR5 swap. I also have a SR5 cluster if your interested:D
    James
  4. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    89-91 has a mechanical speedo. 92-95 has an electric speedo.
    And I personally liked when I had a 92, I swapped the gauges faces for 89-91 from a parts cluster. Just slighty different font and increment dashes. /useless trivia haha.
  5. Toyo Trucker
    Toyo Trucker Addict
    Sorry to rain on your thread "sitnlow4life" but, can anyone give me some pointers to why my speedo don't work.
    1. connection to drivetrain
    2. connection to cluster
    3. speedo is just out ( temp/gas still works)
  6. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    I too had this problem after I installed my cluster & come to find out that the connection/cable on the back of the cluster was on 100%. Might want to check that just to be sure.
    This link is for the 84-88 cluster, but I used it when I did my swap & worked for me...http://www.humboldt.edu/~pke1/Truck/
  7. MacRib
    MacRib Enthusiast
    San Diego
    90 4runner, 94 standard cab, 90 standard cab STOLEN
    Oil pressure switches
    What oil pressure switch are you guys using when you swap tach's? Is the switch for an 84-88 the same as 89-95 with a gauge? I've been looking at different places and getting different part #'s and prices (35-75 bucks). I'm getting ready to do a swap too and the switch is the last piece I need. I found 2 4cyl 4runners at the wrecking yard and picked up a tach out of one of them. I was going to grab the switch out of the truck too but it was a Cash 4 clunkers car and they put something in the motors to seize them so I didn't want to mess with that. Other than that that program is putting some nice stuff out there(except for the engines).
