Has anyone hooked up a tach to a 22r. if so where do you put the green cable in on the coil. please post pics of it. cause i was told that I might need to get a "tach adaptor"
no tach adeapter needed, and the green cable goes on the negative of the coil, and since its a 4 cyl, u need to cut two of the wire on the back, make sure u cut the correct two.
