Suspension wiggle
Discussion in 'Suspension/Chassis' started by planemos, Mar 21, 2010.
  1. planemos
    planemos Toyotaholic
    British Columbia
    I have noticed that my rear end wiggles easily when I apply pressure to the sides of my bed. I noticed my shackles need replacing. Would new shackles fix the wiggle? Or do I need spring bushings as well? What else could cause the wiggle effect?
  2. Litneon
    Cocoa, FL
    94 xtra cab
    Well, I see that you have an xtra cab. There in lies most of the problem. I noticed a year or so ago that mine does the same thing. I have replaced almost everything in the rear. I believe that it is caused by the long frame and the little bit of extra flex due to the extra length....
  3. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    what size tires and wheels do you run? most of that "wiggle" side motion is from the tire sidewall....
  4. planemos
    British Columbia
    Ya I think so. I had it sitting on the concrete garage floor. They are 31x10.5BFG M/Ts right now. Mounted on 15"s. Okay well thanks guys. I just need shackles.
  5. Evolmotorsports
    Evolmotorsports Veteran
    SCV cali
    1987 RN50 Hilux
    You can check you leaf bushings by scrapping the rubber bushings with a screwdriver if it flakes apart change them, but even so having a 92 with 31's would probly be a cause for replacing them with poly ones anyway.:waytogo:
  6. planemos
    British Columbia
    You're even more right than you think you are. Thanks. It's an '88. 92 is my 2wheel drive.
