Supra diff?
Discussion in 'Off Topic' started by 86extTURBO, May 13, 2013.
  1. 86extTURBO
    86extTURBO Veteran
    CA
    1986 ext cab Turbo
    Is there any info on putting supra LSD in a pickup rear end. Are they direct bolt ins or do you need a bigger axle or something? Any info would be great thanx.
  2. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    7.5 mk2 supra diff swaps in
    8 inc mk3 supra diff drops in keeping one baring and race from the supra it's pretty simple
  3. 86extTURBO
    86extTURBO Veteran
    CA
    1986 ext cab Turbo
    That's awesome now I just have to figure out what rear I have and to find an LSD why did you mean by keeping one bearing though?
  4. Seventy6Celica
    Seventy6Celica Member
    San Gabriel Valley
    75 Hilux
  5. 86extTURBO
    86extTURBO Veteran
    CA
    1986 ext cab Turbo
    I'm not very sure on how to go about this is this a hard swap to do on your own or Gould I have a shop do it and what gear ratio would be best for daily driving
  6. Seventy6Celica
    San Gabriel Valley
    75 Hilux
    It's not difficult, it's just attention to detail. There's a lot of putting together, measuring, taking apart to adjust, put back together, measure, take apart, adjust....
    Or you can get really lucky and get it all right the first time. My experience was a little different from a standard swap because I machined the supra carrier to accept the truck carrier bearings. Other than that, it was a pretty straight forward swap. I also had to grind the opening on the axle housing because the ring gear was hitting it, and I had to shorten the passenger side (I think) axle about a 1/4". If you can rebuild your engine, you can do this.
    The link inside my post is a very good step by step. It will help a lot.
  7. 86extTURBO
    86extTURBO Veteran
    CA
    1986 ext cab Turbo
    I don't have the tools to do that build in that link unfortunately
  8. 86extTURBO
    86extTURBO Veteran
    CA
    1986 ext cab Turbo
    You wana do mine lol
  9. NashMan
    NashMan Toyotaholic
    94 2wd
    all ya need is dail gauge and some marking paint
    check the gear pattern with paint if ok this gets rid of annoying step. if it's good swap the lsd units and swap ring gears
    since the toyota truck just use threaded cage's on eather side make adjustments really fast once you go stake the cages tighten down the cages
    I try for like 8 thou back lash
  10. IronNam
    Find out which axle you have first.
  11. 86extTURBO
    86extTURBO Veteran
    CA
    1986 ext cab Turbo
    Mine is a turbo and going by codes I have an 8
  12. NashMan
    NashMan Toyotaholic
    94 2wd
    i have an lsd unit wiht upgrade kit for sael if you are interested
