street piston +.20'' (+.50mm)
Discussion in 'Engine/Drivetrain' started by yota89, Apr 29, 2014.
  1. yota89
    yota89 Enthusiast
    guam
    89 single cab
  2. Litneon
    Cocoa, FL
    94 xtra cab
    Boring a cylinder is usually only done to square up the cylinder walls. The displacement gained is minimal (really), and how far the cylinder gets bored is usually determined by the machinist when he measures the taper of the cylinder.
    I usually drop the block off to my local shop, and they tell me what size pistons and bearings to order. Takes a few extra days, but better than ordering the wrong stuff.
  3. Ryno5150
    Ryno5150 Member
    Suwanee, GA
    89 2WD reg cab, 85 4Runner
    I do the same as Litneon. I drop off the block at the machine shop, they determine how much it needs to be bored out, order the pistons, measure the pistons, then bore the cylinders accordingly to make a fit. For example, the engine I put in my 89 had sat for a long time, and had rust on the cylinder walls, had to be bored 0.040" over. The engine I put in my 4Runner only had to be bored 0.020"
