straight axle question
Discussion in 'Engine/Drivetrain' started by 22r, Jul 8, 2010.
  1. 22r
    22r Veteran
    Maui
    i have a IFS truck with the factory 4.10's i believe and i was wondering if the third member from my IFS will fit directly to a 1984-1985 toyota straight front axle with no problems?
  2. shin
    shin Member
    cheese,wi
    91 base
    here is what i got from your question: is that you have a 4wd truck around and you want to take the third from that and put it in your 2wd..... and i would believe it should built in due to i know the 4wd has a 8" diff... run the axle codes and if the first digit is the same for the axle code it should bolt right in..
  3. Nook
    Nook Addict
    oregon
    The IFS truck uses a 8" rear and 7.5" front third member, the rear unit will fit the straight axle but the front IFS unit won't.
  4. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    you doing a 4wd solid axle swap?
  5. planemos
    planemos Toyotaholic
    British Columbia
    This might help. Answer this: Can I use the front 3rd member from my 1986-1989 4x4 as a replacement for my front 3rd member for my 1989-1995 4x4?
  6. 22r
    22r Veteran
    Maui
    thanks nook!
  7. 22r
    22r Veteran
    Maui
    in that case i may as well put the matching rear end on my truck to then.
  8. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    No can do... As previously stated IFS 3rd's are 7.5" whereas 79-85 front straight axles are 8"....
  9. 22r
    22r Veteran
    Maui
    so can i put a 1989 rear third member in a 1985 solid front axle? will it spin the right way and hold up?
  10. B.Y.E.
    B.Y.E. Toyotaholic
    1982 2wd Hilux
    Yup! That's the beauty of Toyota... :waytogo:
  11. 22r
    22r Veteran
    Maui
    OMG!!!:clapping: (the song "a whole new world" plays in the background)
