Squealing after clutch
Discussion in 'Engine/Drivetrain' started by Waystro, May 30, 2020.
  1. Waystro
    Waystro Newbie
    Just got trans all buttoned back up no gears when running and it is squealing from the shift fork/slave area soft peddle to I didn’t do the bearing because it looked pretty good any ideas??
  2. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Always change the throw out & pilot bearings.
    May be one of those or you have th e fork in wrong.
  3. Waystro
    Waystro Newbie
    Fork is exactly how it was in I just put the throw out bearing in and still doing to same thing. Buddy pushed the clutch in and it starts making noise also the truck was missing the 2 side bolts(starter side and then drivers side I just looked again and it’s not seated fully on the alignment dowels I’m assuming because those bolts aren’t there
  4. Waystro
    Waystro Newbie
    Update no noise now but still not going into gear while running
  5. sirdeuce
    sirdeuce Veteran
    '86 4Runner and '89 2WD
    Did you put the clutch plate in backwards? Just a thought. If the pedal is soft, maybe bleed the system, top off fluid.
  6. Waystro
    Waystro Newbie
    Shift fork came off the ball haha simple fix but took me a minute.
  7. sirdeuce
    sirdeuce Veteran
    Ok, that's a new one to me.
