Speedometer has cruded out i think. It will not do a thing. I used to be able to flick it, and it would work again. It completely stopped right when it started raining like hell down here in SD. Any ideas on where to start?
It decided to start working again when i hit 80 on the freeway, and then i stopped,and it didn't come back on.
Mine was reading too high, then it started working, then on/off, now its high again. I think its a bad ground somewhere- speedometer is electric. So if you can figure it out let us know. http://www.toyotaminis.com/forum/showthread.php?t=2425
Mine does something similar. Every so often (it's not regular, or at least I don't see a pattern) the speedo won't work when I first start but it will engage after some time. I'm just glad I have my GPS so at least I know my speed.
speedo issue i had a similar problem, it did not work till i reach 40KMPH and after that works ok. got it dismantled and checked by a shop to find out some loose soldering on the back of the PCB. re soldered and now ok. chamara
Re solider new parts in. Look around for other post on you tube. Found one that replaced more parts. If I find it again I will post it.
