sparco seats?
Discussion in 'Interior/Electronics' started by 87pickup, Jun 11, 2011.
  1. 87pickup
    87pickup Member
    ontario ca
    87 single cab short bed
    I bought a pair of sparco seat but my truck has a bench seat is there special mounts. Or can I get one off a different truck or do I have to custom fab a set?
  2. jetas
    cant u fit your stock seat tracks on the sparco seats?
  3. 87pickup
    87pickup Member
    ontario ca
    Its at bench seat so I only have the two outer ones
  4. jetas
    You would need the inner tracks from a set of buckets
  5. 87pickup
    87pickup Member
    ontario ca
    Wear can I get those?
  6. jetas
    Easiest i could think is the junkyard. The tracks should unbolt from the seat frame. If the mounting points dont line up then youl most likely have to fab some new brackets
  7. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    Well also depends on if the Sparco's are set up for side mount brackets or bottom mount. If you bought them new from a store or ebay they should have come with universal sliders. If they did then yah all you gotta buy is rails for toyota bucket seats for the same year range. Make sure though you get them for the cab you have cause standard and xcab brackets are different. Like Jettas said probably junkyard, or ebay. The dealer might be able to get them but prob not. Honda civic 92-95 brackets are pretty close but you would have to mod them a bit.
  8. JOE_1985
    JOE_1985 Veteran
    87 custom
    use 4 runner brakets, your going to have to drill/grind off the rivits that hold them though
  9. garagedoorman
    garagedoorman Addict
    north georgia
    seat pics
  10. tony714
    tony714 Member
    Anaheim Ca. 92801
    88 lolux
    not true about outer bolts only.....i had a bench seat in my 88 pickup and when i took it off under the carpet hidden were the inner bolts....i have civic si seats in it and fit nice.....the only holes u need to make are the back inside ones
