Hi people So I think I have a wiring/fuse issue with my brake lights. My turn signals work. And my running lights work. But nothing when I step on my brake pedal. I also lost my fuse panel cover for the fuse box in the kick panel under the driver's side. It would help me out so much if someone had a pic or could take a pic of that diagram, which is on the back of the access panel for the fuses. Thanks. Please help!
I just noticed it when putting my truck back together after bagging it. If I remember correctly it was like that when I had it on the road last. I found a ground wire at the rear that might fix the problem. The ground wire isn't hooked up yet. That is all I can think of. But all the signals and running lights work on the tails. Just not the brake lights it is weird.
Yea you're right. I narrowed it down to the switch. Where is the stop light switch? I hooked up the ground and tried hitting the brake pedal. No stop lights. I tried with the key on, still nothing.
