RV sway bar!
Discussion in 'Suspension/Chassis' started by scoob., Dec 11, 2013.
  1. scoob.
    scoob. Member
    Ive got a lead on an '87 toyota RV/camper in the yard and i am wondering, if i use the brackets, links, bushings, ect. could i run the front sway bar on my '92 1/2 2wd pickup?
    Looking forward to some info! Thanks!
  2. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    yes you can... however you'll want to make sure that the sway bar out of that is thicker than the one you already have. look at your factory one and look at the side of the bushing... it should have a 18 or a 23 on it witch means the size of the bar... then compare it to the one you found... should say a number on it as well.... the 1 ton bars will be 25mm thick.
  3. scoob.
    scoob. Member
    Awesome! Thank you for the response!
