right rear bearing replacement
Discussion in 'Maintenance/Repair' started by jdh1960, Feb 10, 2013.
  1. jdh1960
    jdh1960 Newbie
    I replaced the right rear bearing and that went just fine. Can not get the breaks bled to my satisfaction. been trying and trying. Only had the 1 break line opened. Have bled all 4 and the LSPV.
    Please advise. :verdict_in:
  2. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    What I usually do when I need to crack open a brake line or have to pull one off for some reason is line lock the nearest soft line(hydrolic hose) with a vise grip.Are they all hard lines after the proportioning valve?Can't remember right now.Anyways are you getting a good squirt out of all the nipples?Just remember if your truck is dropped in the rear that proportioning valve could be the problem.proper bleeding order is LR RR RF LF LSPV.
  3. jdh1960
    jdh1960 Newbie
    Thanks,
