Reworked dash & new upholstery
Discussion in 'Interior/Electronics' started by TRUCK ACTION, Mar 10, 2008.
  1. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Reworked the dash,repainted & clear coated,also got my seats recovered[​IMG]:cool:
  2. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
  3. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
  4. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Also made a patch for the corners @ the headliner( one side was torn) will redo the whole thing later!:cool:
  5. east1la
    east1la Enthusiast
    nc
    1993 toyota pickup dually
    nice. what type of paint did u used?
  6. patriotpop
    patriotpop Addict
    Baltimore, MD
    94 2wd
    Dam, that looks great!!
  7. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    OMNI AU MBC base coat, & OMNI SV MC262 clear coat/MH266 hardener,
    this is made by PPG:cool:
  8. east1la
    east1la Enthusiast
    nc
    thanks. I'm planning painting my interior.
  9. JOE_1985
    JOE_1985 Veteran
    87 custom
    what kinda seats are those? and how hard was it to redo the dash?
  10. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    The seats are the stock SR5's,recovered keeping the same stitch design.
    The dash started by removing all the cracked & lose material[​IMG]
    I left as much material as possible @ the vent openings so to keep the shape & size of the opening!
  11. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Then I filled the coin dish with a high density foam epoxied in,then started laying fiberglass[​IMG]
  12. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Followed by body filler & lots of sanding[​IMG]. Once to the shape & smoothness that you like,primer & paint.:cool:
  13. Zwalker
    Zwalker Enthusiast
    Pe-whore-ia, Arizona
    86 4x4 xcab
    Think u could tell me all the products u used (and who makes them)?
  14. jrknsrk08
    jrknsrk08 Member
    Sierra Madre, CA
    88 single cab 2wd
    looks great. good job.
  15. PapaBear1013
    PapaBear1013 Addict
    Lancaster, Cali
    1994 Std Cab
    Wow great job! I know it inspires me to work on my truck some more! Again, looks good bro! :waytogo:
  16. JOE_1985
    JOE_1985 Veteran
    87 custom
    iwas more curious of how u set up the guages and whatnot
  17. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    All the fiberglass stuff is from Tap Plastic,I used the Marine resin as it holds up better to sunlight & heat. The body filler I only use Evercoat, long strand for deep fills & short strand for every thing else & finish off with Evercoat Metal Glaze,as a fine coat.
    Primer I use PPG Epoxy Primer,as seals very good.
    Just take your time,don't lay paint until all is as smooth as you can get!:cool:
  18. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    To start on the gauges I got a donner cluster & cut the back section down to only what I needed[​IMG]
    A Zip cutter in a air tool works great for this!
  19. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I made patterns of the pieces that would make up the new cluster[​IMG]
  20. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Some the the circuitry had to be removed from the stock circuit board to keep the engine on test lights for smog reasons[​IMG]
