Help, in checking out my 1993 22re pickup truck, I noticed the end of the electrical connection that clips on the oil temp. sensor under my truck engine , had broken off ! The wire connected to the clip part is cut right at the end leaving no way to mend back together. Is there a way I can fix this myself ? Would I have to replace all the wires related to sensor ? Do they sell this as a kit or something ? Thank everyone in advance who can help me out !!!!!!
Didn't know they had an oil temp sensor... Oil pressure wire should be able to clip on with a cheap female spade terminal. Same for early style water temp gauge sender (1 wire) (but not ECU or CSI 2 wire water temp sensors)
