Removeable notch cover repair
Discussion in 'Exterior/Body' started by TRUCK ACTION, Dec 10, 2015.
  1. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    So my 2nd winter project is repairing the tabs for the aircraft type lock down buttons ( ZLoc fasteners). The tabs were welded to the edge of the notch cover body,not enough area to have any strength, hence they would bend!!
    The fix, weld new tabs to a plate that goes under the notch body, which I attached with pop rivets so can be removed if needed!! Much stronger!!
    At the same time I added strength to the two metal bands that are welded under the cover to keep from flexing, drilled & tapped the bands so stainless button heads could be inserted! :cool:
