got a 93 ext. cab. wont to remove the rear seat and build a large storage box that will hold a 10" sub and 2 6x9s. building the box will not be a problem. im trying to find a way to pull everything out. the drop down seats and the storage box that is under the seats. any info will be great. thanks. mike.
The rear seats are pretty easy to take out...I think they bolts are 10mm and to get to them just flip the seat up. You see a trim panel that runs along the bottom of the the extra-cab/under the top part of the seat. Take that panel off-(should just pull off) & youll see the bolts that hold the flip down seats to the wall. Once you take the flip down seats out the only part left is the top part of the seat & there are 3 bolts that hold it on as well. Youll also have to take the top panel off-(the one above the seat) to get access to the bolts on top. Hope this helps. *Oh & as for the storage boxes under the seats then just leave the panels that are on there in place cause it will just leave big holes!
yeah i think that will help. ill look tomorrow. but as far as the storage boxes that are under the seats, how difficult is it to take out? cause i want the box that i want to build will go to the floor of the cab in order to work. again thanks for the info about the seats. i will have to look at it before i go to work tomorrow.
