rear end ?'s
Discussion in 'Suspension/Chassis' started by neverdone, Dec 10, 2009.
  1. neverdone
    neverdone Member
    spring hill,fl (352)
    86 bodied yota
    i have a 86 toyota rear end from a single cab short bed (1pc d-shaft)....i want to swap this rear in a 83 nissan/datsun king cab which has a 2pc d-shaft....will the 2nd d-shaft from the nissan bolt up to the toyota rear?...any info would be awesome
    thx
    lunchboxxx
  2. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    may be able to if you redrill the flanges....... again.. seth may be the one to pose this question to as i think he's used toyota running gear to do a 5 lug conversion on a nissan before....
  3. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    I'm sure it won't be a bolt on and go deal but, very doable... Driveshaft length would be your problem area. You can always re-drill the pinion flange (like mentioned above) or find an old yota shaft and cut the yolk off...
    I believe you'll have to move the saddle mounts for the leafs aswell.
    I take it you going 5 lug for a better wheel selection???
  4. IronNam
    toyota's have 5lugs... from what i know lol
  5. 22r
    22r Veteran
    Maui
    i would say the 4wd rear ends would be better cuz of the same # of studs and bolt pattern. and i dont think the driveshaft might fit. and if u drill out the holes on the flange it may not spin right and could cause a vibration when u drive.
  6. SD YOTA
    i think he's looking to do a 5 lug conversion for better wheel options....
  7. camel84
    camel84 Member
    Ontario, Ca.
    84 xcab 22re
    OK , if you are tring to do a 5lug conversion its easy. dont get a new nissan axels and hubs thats to much work and you'll still have nissan parts. they make alloy axels for toyota and you can get them drilled to whatever you want. CAL ALLOY makes the front hubs that fit anywheel lug pattern .if your that involved in it theres a machine shop in riverside ca. i can get the name and number the do great work and they are cheap. my buddy got some 5x5 hubs for his toyota for like 300 for both and they are 6061 t6 bitchn billet parts and i know they have the blue prints.
  8. neverdone
    neverdone Member
    86 bodied yota
    yea, heres the situation...sry i dodnt elaborate before...i own a stock 83 720 ext cab and a 86 bagged reg cab toyota, i want to swap the toyota rear and front end assembly because i have 19's on the yota, so yea it would be a 5-lug conversion, trying to do this the right way but salvaging as air ride/suspension parts as i can, so i'm just curious to see if the nissan driveshaft will fit the yota rear and will the yota spindals/brake assembly work with nissan arms?....if not im willing to do the work but i was just trying to save time because its a personal truck not a customers...thx guys
  9. neverdone
    neverdone Member
    86 bodied yota
    o and obviously going with that bagged set up i would be throwing my reverse 4-link in there which would take place of the leafs
