Questions about cams
Discussion in 'Engine/Drivetrain' started by HiLuxDreams, Mar 1, 2021.
  1. HiLuxDreams
    HiLuxDreams Member
    Guam
    91 Hilux 22RE
    So I was wondering if there were any aftermarket cams that are unmarked? Reason why I ask is because I was convinced there was an aftermarket cam when I bought the truck due to how much the engine rocked when revved. Anyways, had to change the valve cover gasket so figured that was a good time to check if it was stamped so I can identify it. No stamp...what would cause the engine to rock like it has cams if it is a stock cam?
    Please note that I'm still learning :shrug:
  2. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    Worn out motor mounts..
    HiLuxDreams likes this.
  3. HiLuxDreams
    HiLuxDreams Member
    Guam
    91 Hilux 22RE
    :( thanks for the reply
    Erwin Merida likes this.
  4. sirdeuce
    sirdeuce Veteran
    '86 4Runner and '89 2WD
    Worn motor mounts could be one issue, at least the engine would seem free. Other things to consider are worn lobes on the cam or bad cam timing. Possibly a bad accelerator pump(if carburetted). Poor tune...
    Any of those could cause a rough enough running scenario to make the engine jump around.
  5. HiLuxDreams
    HiLuxDreams Member
    Guam
    91 Hilux 22RE
    Thanks for the reply. I'll have to double check the timing when I have a day off from work. I have a 22re and I had a friend who suggested that it may be that the previous owner tricked out the EFI. Personally I'm not too sure what that means but I hope there is a way to "un-trick" the EFI since I'm not racing the truck.
