Question about a couple things under the hood
Discussion in 'Engine/Drivetrain' started by SamuelsToy, Sep 19, 2010.
  1. SamuelsToy
    SamuelsToy Member
    Grifton, NC
    1994 xcab pickup
    im trying to cut the inner fender wells out, but i have to move things around, i have read up here a while back that some stuff is not needed, therefore can be gotten rid of, so my questions are the parts in the pics what are they? are they needed, and can they be removed without hurting performance? and in the second pic the cable attached to the black box in the corner runs to the efi, so i beleive it has something to do with the throttle, so my question about that is, what exactly is it? thanx for any help.
      File size:
      72.3 KB
      73
      File size:
      61.5 KB
      72
  2. toylowta
    toylowta Enthusiast
    river valley arkansas
    94 single cab
    you dont need any of that stuff its your charcol canister i dont have it on my truck, an the other is your cruise control if you want it just relocate it, if not get rid of it
  3. project_DragTruck_v2.0
    project_DragTruck_v2.0 Veteran
    note, once your charcoal canisters are removed, you'll notice a rush of air when you open the gas cap. I'm unsure if it's sucking air into the tank, or blowing fumes out ( i would think sucking air in), either way...that's the only difference you'll notice.
  4. toylowta
    toylowta Enthusiast
    94 single cab
    well if you have a good gas cap where it can breath it wont do that. cuz i bought me a gas cap an i dont have a problem with that
  5. planemos
    planemos Toyotaholic
    British Columbia
    Relocation relocation relocation. :D
    The charcoal canister can work if it is right next to the gas tank also.
  6. SamuelsToy
    SamuelsToy Member
    Grifton, NC
    1994 xcab pickup
    so, it wont hurt anything to get rid of any of that stuff? and is there anything else that is not needed that i can get rid of? like the piece bolted to the header?
  7. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    If you remove the charcoal canister and leave the line open, it'll vent gasoline vapor into th engine bay when it warms up, and suck fresh air in when it cools off. if it goes whoof when you open the gas cap it's because the line was capped off. BTW it's pushing out, the gas cap is vented with a check valve so it can pull in fresh air but not release hydrocarbons (evaporated gas)
  8. IronNam
    basically it allows you to keep the fumes and re-use it. I'm gunna leave mine in.
