Power steering swap
Discussion in 'Suspension/Chassis' started by SD YOTA, May 29, 2009.
  1. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    has anyone swapped over from a manual to power steering setup? know what needs to be done? what parts are needed? is it a bolt-on swap? im thinking about doing this swap given ive heard rumors that its fairly simple, i just never looked into it in depth.
  2. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    I believe Trap just added power steering to his.
  3. the_general626
    La Mirada, CA
    toyo trucker hit him up
  4. trap
    trap Addict
    orange county ca
    92 pickup
    I did just add power steering.
    Off the top of my head you will need;
    -2 or 3 different brackets for the pump
    -p/s pump
    -p/s reservoir
    -p/s gear box
    -shorter length steering shaft
    -low pressure line
    -high pressure line with cooler
    -idler pulley
    -crank pulley
    -approximately 4 feet of vaccum hose.
    -another belt
    -a lot of bolts
  5. MacRib
    MacRib Enthusiast
    San Diego
    90 4runner, 94 standard cab, 90 standard cab STOLEN
    Hey Al there's a guy on ebay with a complete set up... gear box, pump, reservoir, hoses, brackets, the whole nine yards.
  6. SD YOTA
    thanks guys...... i had an opportunity to buy the whole setup for $100 bux but not sure its still available... havent been able to get a hold of the guy who had it.
    Mac, got a link to that ebay page?
  7. Evolmotorsports
    Evolmotorsports Veteran
    SCV cali
    1987 RN50 Hilux
    I did it on my truck it is simple like a level 4 to install, but hey if you can get a vacuum asist pump from a later model they work way better, and are easy to tap in to your existing lines.
  8. SD YOTA
    yea, im definately looking into it.... i need to finish up my motor build and i think im gonna go with that setup!
    on a side not yet relative topic....... i found out recently that my toyota mini truck salvage yard is back and in full swing! ill be hitting them back up for my toyota parts needs :D
