Poject:73 Bondo Lux!
Discussion in 'Pre-1975 Build-Up/Project Threads' started by Squigy, Aug 13, 2014.
  1. Squigy
    Squigy Member
    west palm biatch, flo-rida
    1973 Toy Hilux
    Well finally got the truck running great, stopping awsome with the front disc set up.
    Time to de-bondo the driver side. The driver side rocker has 1 1/2 thick bondo, the door has about an inch.Plan is to cut the doo skin off and get another door skin and weld it in, the rockers will be cut out and replaced with new metal. Pretty simple on the rockers, now the door skin will be a challenge to find, unless i find a whole door will save me tons of time.
    Under the fender the sub frame or cowl area is pretty solid just surface rust will be sanded and rust proofed.
    here are a couple pics of what i am starting with.:duh:
    It takes just as long to smooth the filler out than to just take the damn door off and replace it.:silly:
    Wish me luck PLEASE!!:p
  2. jetas
    Holy hell looks like they didnt even try to pull the dent out at all.
  3. Squigy
    Squigy Member
    1973 Toy Hilux
    Yup thats how it be in the Flo-ride-duh!
    My last truck was from Washington State zero rust!
    It was a 1972 Ford Courier on bags, but like i said no rust at all.
    This Toyo is not bad but the door and rocker are garbage.
    We will see about the floor after the door and rocker is done.
  4. Squigy
    Squigy Member
    1973 Toy Hilux
    Well i knew this **** would happen!
    Called Friday for the door skin told the yard i would pay right then
    Of course i gave them extra day just in case i call today i get another yahoo tells me that they dont do that...
    Granted i spoke to the owner on Friday. But he was off today, well lets see what happens tomorrow.
    This door thing is really becoming a pain in my ass!
    Its no wonder why they bondoed the crap out of the door!
    Sorry had to vent!
  5. Squigy
    Squigy Member
    1973 Toy Hilux
    Little update
    Got to grind, chizzled, hammered, swore!!
    Public service announcement: Stop using Body Filler ! Skim coats only not two inches!
  6. Squigy
    Squigy Member
    1973 Toy Hilux
    Another pic
  7. Squigy
    Squigy Member
    1973 Toy Hilux
    Another pic.
  8. jetas
    Thats an insane amount of body filler. I surprised it even stayed on there
  9. Squigy
    Squigy Member
    1973 Toy Hilux
    Me 2!! o-0
    All gonna be replaced with metal!!
  10. Squigy
    Squigy Member
    1973 Toy Hilux
    Ok so i could not purchase a new rocker..:(
    So i ve had a pair of rocker panels from a 1971 camaro.
    Turns out with a lil cutting shifting welding it will work perfect!
  11. jetas
    Alot of massaging for it to fit?
  12. Squigy
    Squigy Member
    1973 Toy Hilux
    Nope..
    Only difference is the actual rocker curve is backwards on the Camaro rocker.
    So i will post pics from my computer.
  13. Squigy
    Squigy Member
    1973 Toy Hilux
    Woohoo scored a pass. Fender, now just have to find driver side door, and fender!:-/
  14. Squigy
    Squigy Member
    1973 Toy Hilux
    Almost done with the outer rocker drivers side.
    Took another 3 lbs of bondo off the driver side door
    Unscrewed the self tappers holding down the 22 ga aluminum and there is a floor panel that is not very bad under all that shaddy **** work
  15. Squigy
    Squigy Member
    1973 Toy Hilux
    finally found a good door and only $20.00, lost out on the driver fender..
  16. Squigy
    Squigy Member
    1973 Toy Hilux
    Thank you ePay for non-paying a-h&*Les!
    I got both front fenders for $25.00!!! Yippppeee!
    Got the door today. Its like Christmas,Kwanza,Hanukkah, and all others.(trying to be PC)
    I will ad photos soon for those that care.
  17. three
    three Newbie
    Seems like it's coming along. :) Any pics / info (parts you went with / process) on the brake swap?
  18. DoodleBugg
    DoodleBugg Member
    Going to look good an u are doing it right
  19. Squigy
    Squigy Member
    1973 Toy Hilux
    Brake swap off a 78 truck, complete straight bolt in.
    There are a couple threads about how to do the swap.hope that helps.
  20. Squigy
    Squigy Member
    1973 Toy Hilux
    Does anyone know where i can get floor pans??
    Or will i have to make some?
