How do you do a reverse light and blinker swap for the tail lights?? Also how do you do a blinker and parking light swap for the front?? Thanks!!
I would imagine you must cut the wires from one and connect them to the other. If you want the front corner lights to work with the first click of the headlight switch by the steering wheel AND serve as the signal I'm not sure how you would do that. You would have to figure out how the system works. I know there are grounds and fuses (other stuff probly too) to worry about.
