PITA 22RE 17mm Trans Bolt removal
Discussion in 'Engine/Drivetrain' started by Chikn Hawk, Aug 14, 2014.
  1. Chikn Hawk
    Chikn Hawk Member
    671 Guahan
    94' X-Cab Toy Lux
    I have a 1994 22re Xcab hilux and working on upgrading my stock clutch. The problem is the upper housing 17mm bolts are hard to loosen :mad: and more particularly the one on the driver's side :shrug:. I was excited :funnyup: to work the clutch but now im fukn bummed :cry: that I cant get it out. Your expertise and advice is needed. :confused:
    TIA :bowdown:
  2. yotarip
    yotarip Veteran
    My recipe for that is:
    1) drop the trans x member to allow the engine to tilt back and allow more clearance.
    2) 17mm socket 1/2" drive
    3) 1/2" universal
    4) about 2 feet of 1/2 extensions
    5) 1/2" breaker bar
    6) lots of cussing
  3. boner.too
    boner.too Enthusiast
    Guam
    1994 single cab
    i usually get the top bolts from the engine bay
  4. Chikn Hawk
    Chikn Hawk Member
    671 Guahan
    94' X-Cab Toy Lux
    Thanks IDK how much more cussing I can give but thanks for the info.
  5. Chikn Hawk
    Chikn Hawk Member
    671 Guahan
    94' X-Cab Toy Lux
    I did the passenger side from the bay but the other bolt is a PITA. Not much room
  6. Cherry Picker
    Cherry Picker Newbie
    Muncie IN
    1987 RWD DLX Xtra Cab
    17mm ratchet box wrench worked for me make sure its the ultra ratio click type you have no room for wrenching there
