Oxygen sensor on 22r (carb)?
Discussion in 'Engine/Drivetrain' started by aseq, May 4, 2013.
  1. aseq
    aseq Member
    CA Bay Area
    87 2wd, Carb, Longbed xtra cab
    I have an 87 longbed xcab 2wd with carburetor (CA model afaics) and it has what looks like an oxygen sensor stuck in the exhaust (header?). It's visible when looking down from the driver's side, it has one wire. Now I thought that engines with carburetors don't come with an oxygen sensor, since there is no computer to do anything with the data collected (so what's the point?). In addition I am unable to actually find it listed on the label under the hood, neither in any of the manuals.
    Is it an oxygen sensor, if not, what is it?
  2. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    its for the emissions computer system. in your passenger kick panel you will see an ecu there for all the smog/emissions stuff. there isnt much to it but everything under the hood with a green plug is in one way or another tied into the emissions. (atleast on the passenger side of the engine bay and the 02 sensor)
  3. Turbo Blow Through
    Turbo Blow Through Addict
    austin tx
    87 hilux
    How do you remove it and keep the vehicle running doesn't it control the solenoid in the side of the carb?
  4. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    I removed all the emission sensors. Then upgraded to a weber carb shortly after.
  5. aseq
    aseq Member
    CA Bay Area
    I am surprised, I honestly thought the engines with a carburetor had no ECU. I am wondering how the ECU in turn controls the fuel mixture since a carb is mostly a mechanical device.
  6. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Toyota maid a somewhat of a lame emissions system for Cali emission standards back then a cruel and hagard attempt to pass there standards .. Somewhat helped but at the same time redundant system ..
  7. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    yup basically lol.
  8. aseq
    aseq Member
    CA Bay Area
    Thanks, I guess that explains it. :)
