Alright recently something under the hood been leaking. I thought it was oil but my stick reads full. Power steering is full. brake fluid is full. Everytime after i drive and take a look under the hood the area under the intake manifold is wet and looks fresh. Someone told me theres a sensor there, dunno if thats why. Also i need to replace my timing chain soon so dunno if that could be adding to it. Anywho i took some pics, and circled the areas. If anyone got some help/advice/pointers it would appreciated. Also anyone know why my radiator hose is leaking? I recently changed it out. Anyone?
Picures arn't working. If you have the stock intake manifold, there is a coolant passage on the bottom of it with a sensor hooked up there. Common for this gasket to leak. Its not a big deal and won't cause any problems. Change out the gasket and make sure the threads arn't stripped. Your collant hose may be leaking cuz its not tightened enough or may be punctured/teared. Just do some checks.
