offset
Discussion in 'Wheels/Tires' started by the_general626, Jun 16, 2009.
  1. the_general626
    La Mirada, CA
    anyone kno how to check the offset of a rim?
  2. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    usually wheels have them stamped on the inside of the wheels.
    you can also check the distance on the inside of the wheel from the mounting surface to the outter edge of the wheel.
  3. the_general626
    La Mirada, CA
    k but will that tell me the negativity or positivity
  4. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    Here
    http://www.tirerack.com/wheels/tech/techpage.jsp?techid=101
    That explains it decent. Most rims are a positive offset, which means the centerline of the rim is pulled to the car more. As offset goes down in size the centerline of the rim gets moved out away from the car.
    On our trucks a a 50mm offset leaves a space between the tire edge and the fender lip. When you bring it down to say a 30mm the gap between the tire edge and fender is much smaller.
