so about 4weeks ago i crashed my truck had to cut the front end off and get another one welded that means that to take off my front end i had to undo some of the wiering so i did that now that its done i put it back 2gether and there is no powere when i turn the key anyhelp would be great thx guy/girls
If your not getting power at all I would start buy checking ground wires and your power wires in the engine bay that lead to the fuse block under the hood also the battery what condition is it in was it in the collision
battery is good nothing happen to it got it cheked and charged cuz it was siting for 4 weeks and bettery came up good ok so im a start by cheking all my grounds by power wires witch would they be?
na it wasnt split just that the plastice around it was all broken and **** u no how were that 80 fuse gose the wiers that go to it how are they conected
na was not split but the plastice was all broke so ya got another one also got new ground and positive for battery
I would use a test light and check the terminals coming out of the ignition to make sure power is going to it and also the grounds on it as well. When you try to start it does it click or nothing happens?
Power goes from the battery to that main fuse box than into the cab @ the drivers kick panel to the inside fuse box ,than on to all accessorizes! When you cut the wires was the battery disconnected? If not you lost fuses!! Use a volt meter or test light to back track hot conditions!!
Yeah I recently replaced my alternator and forgot to put the wire on the 10mm nut on top of the alternator and I blew that fuse you are holding.Same symptoms no light no nothing.So that was out and you dont know how to put it back?You have to unbolt the fusebox and put it in from underneath.
TRUCK ACTION: battery was out alredy when i cut i have power on my battery down to my starter but when i turn the key once non of my lights come on at all not even that door buzzer
