Nitro drop 2
Discussion in 'Suspension/Chassis' started by Collin Ramos, Mar 22, 2020.
  1. Collin Ramos
    Collin Ramos Member
    Anybody ever used nitro drop shocks for our trucks? Worth it? I’m going about 3 or 4 inches lower. But a lot of people has been saying they run stock shocks all around. And someone also said the Camaro shocks are the same length as our front shocks. So any recommendations on shocks to run front and back for lowered trucks (rn20, rn23). Thanks!!
  2. jetas
    Camaro shocks are the same exact shock as the ones suggested for our trucks. For the rear if all you are running is blocks then stock replacements should be fine. Hell even if you pull a leaf the same shocks should be fine
    Collin Ramos likes this.
  3. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I had ordered them & they would not fit through the stock a-arms on my 88
  4. Collin Ramos
    Collin Ramos Member
    Thanks again brotha! I’ll look into that. Recommend a brand? Kyb? Monroe?etc.
  5. Collin Ramos
    Collin Ramos Member
    Damn that sucks. I’m guessing oem replacement is the way to go!
