Need side vent solution for '76 Hilux
Discussion in 'Exterior/Body' started by Barnacles, Apr 16, 2013.
  1. Barnacles
    Barnacles Enthusiast
    PAC NW
    89 Hilux - 3VZE
    Does anyone know of a place that carries the side vents (near the door handles on the body) for a '76? See the image below. Does anyone have an extra pair available to sell?
    Both mine are pretty much gone. I'm assuming the '77 and '78 vents are interchangeable, but I can't seem to locate any yet.
  2. 1982rn34
    1982rn34 Addict
    Bay Area 408
    1982 SR5 RN34
  3. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    your truck has the early small vents that came on 73-early 75ish trucks. they are pretty tough to find. usually on ebay. look under rn20/rn22. they do pop up but usually aren't cheap.
  4. Barnacles
    PAC NW
    89 Hilux - 3VZE
    Nice. Thanks for the tip. I'll keep an eye out for some using those terms.
    Haha that was quick - thanks for the info. Do you know if these side vents will bolt up to the '76 spots with a stock look? Has anyone tried this? It looks like they could work, but the recesses for the vents on my truck look a little smaller.
    I really just want something with a stock look to cover up what is currently an eyesore and place for water to get in.
  5. justaguy
    justaguy Member
    75 hilux, 84 xtra cab, 86 1 ton, 87 xtra cab 4x4
    I need a set of the same style too. I have one that was broken and glued back together. I'll post a pic later tonight and you can see what they should look like. Or just check the pics on my thread in the introduce yourself section.there should be one there you can see
  6. justaguy
    justaguy Member
  7. Barnacles
    PAC NW
    89 Hilux - 3VZE
    Cool, an image of just the vent would be nice. I checked out your introduction images and could sorta see them, but a little more detail would help me when cruising the eBay listings.
    Your truck is super clean, by the way! Great color and what looks like good condition. You lucked out!
  8. burnzya
    bodied 73 hilux
    these are the vents you need
    as you can see my 73 had a smaller pillar and they fit better. in 75 the pillar grew and they used the small ones for a little while.
  9. Barnacles
    PAC NW
    89 Hilux - 3VZE
    Thanks for the link and images, guys. I totally understand what I'm looking for. I can see why they break on everyone's rig - too bad they're not made of metal or something more substantial. Maybe I can figure out some sort of replacement piece that will look cooler...
  10. Salty
    Salty Enthusiast
    Just make one out of metal with the same bolt patterns. Maybe even a rectangular air cleaner?
  11. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    It almost looks like you could cut an 8-track in half the long, flat way and end up with a pair of covers.
  12. Barnacles
    PAC NW
    89 Hilux - 3VZE
    Haha this is turning into a good brainstorm! Both of these ideas are great... keep 'em coming. I'm definitely going to look at piles of junk with different eyes now. The 8-track idea is particularly dope.
  13. daruma
    daruma Member
