need help
Discussion in 'Wheels/Tires' started by vegas_yota, Jan 7, 2016.
  1. vegas_yota
    vegas_yota Member
    Im planning on doing a 3inch drop all around and i got my stock 16 inch gs300 rims but they still got the 60 series on them. Wouldi have any trouble with rubbing if i just ran the 60 series ? Should i do a 4 inch drop to compensate for more tire? If anyones got pix of a similar setup id like to see... any help is greatly appriciated
  2. jetas
    Whats the width of the tire?
  3. vegas_yota
    vegas_yota Member
    215... the lexus rim is 16x7.5 +50 ill be adding 25mm spacer to clear hub which will make the backspacing +25 instead of 50
  4. vegas_yota
    vegas_yota Member
    Why does nobody ever reply on this forum
  5. jetas
    Because not everyone has an exact answer.
    Try willtheyfit.com
    Itl help get a visual difference between tire/wheel sizes. Oh and if you would rub at a 3" drop, then going 4" is going to be worse
