Need help with this w/PICS!
Discussion in 'Engine/Drivetrain' started by joeynational, Jan 19, 2010.
  1. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    I'm in the middle of a tune up..02 sensor,coil,cap,rotor,wires,plugs...My truck has been having some hesitating issues and not wanting to start, and when it did it was loping like a big block. After a couple minutes it would smooth out..I found one of my spark plug wires broken. So now i pulled the plugs and this is what I found on #4...Does this mean my rings are worn letting oil into the combustion chamber?
    here are some pics of all cylinders and the plugs they are all in order
  2. joeynational
    PHX,AZ
    91 2WD
    one more of plug #4 one more thing, i did a complete top end rebuild about 3 years ago with new valve stem seals, so more than likely it is the rings right?
  3. IronNam
    I hate #4 sparky... worst place to go into also.
    #4 doesnt look oily... but I'm not 100% sure.
  4. joeynational
    PHX,AZ
    91 2WD
    i think i figured it out..can someone please verify on a 22re, but is there supposed to be a bolt right there where the red line is??? Cuz i don't have one:confused:
  5. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    Plugs look fine to me... The oil on the head is more than likely coming from the half moon grommet under the valve cover gasket, I'm 99.9% sure... Nothing to worry about, just pull it up and put some RTV between the half moon and the head.
    That hole in the last pic is leftover thread from the EGR plate on back of the head, nothing to worry about aswell...
  6. joeynational
    PHX,AZ
    91 2WD
    damn i was hoping it was that bolt...I did check the back of the valve cover(half moon) and its completely dry it just seems to be that corner
  7. B.Y.E.
    B.Y.E. Toyotaholic
    1982 2wd Hilux
    That plate only holds exhaust air and coolant... The only way to get oil in that spot is valve cover/half moon or worst case head gasket...
  8. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    yea...... plugs actually look good. oil is coming from elsewhere.
    change the plugs, do the tune up and see where it gets you. report back on your end results.
  9. IronNam
    and wipe off the oil too. just to see any future "changes"
