Need a direction '91P/U Water Pump Replacement
Discussion in 'Maintenance/Repair' started by KeepGoingForever2, Feb 22, 2015.
  1. KeepGoingForever2
    KeepGoingForever2 Newbie
    Has anyone done a Water Pump job on a 22Re/4cycl/'91? I've got the Radiator out, and not sure where to start from here? Looking for something(belt adjuster?)to get the belts off, but maybe It's the fan/clutch are the items where I need to start, but I'm guessing.... Appreciate any experience offered.
  2. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    I leave the radiator in but since it's already out that's ok.
    If you have power steering and/or air conditioning loosen the nut in the center of the idler pulley and turn the adjuster bolt that is perpendicular to the pulley counterclockwise until the belt(s) can be removed.
    Loosen both the upper and lower alternator bolts and remove the belt.
    Remove the 4 nuts holding the fan clutch to the water pump and remove the fan and pulley.
    Now you can access all the water pump bolts. Remove them paying attention to which hole they came from since some have different lengths.
    Clean the old gasket material off the timing cover and using a gasket likely supplied with the pump reverse the process.
  3. Litneon
    Cocoa, FL
    94 xtra cab
    And keep in mind that re torquing the bolts on the water pump isn't what you think it is. I think they only go to 6 or 7 foot pounds... They will easily strip.
  4. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    They definitely strip way to easy.. next time I do mine I'm putting some inserts in so they hopefully won't as easily.
  5. KeepGoingForever2
    Great advice
    Thanks to those who offered help. Especially, the heads-up caution in re-tightening/torquing the bolts of the water pump itself. Haven't gotten to the job yet, My hands are full, Don't need any more problems....
  6. first80toyota
    Pacific Northwest
    '77 Hilux
    I also like to use some sort of sealant like toyota fipg, that way i dont feel like snugging them down harder and it will still hopefully seal.
  7. KeepGoingForever2
    Idler Pulley Bearing
    Thanks all for your help, ultimately in the end, the problem was an idler pulley Bearing gone bad. Not the Water Pump. Very subtle rattle as it was shaken. Replaced all engine belts during this repair. Looks like hell at 262K now, 22RE good for another 50K, 100K, ??? Retirement anyway....
  8. 390armstrong
    390armstrong Member
    san diego CA
    90 xcab 3.0 vze
