My Front Bag????? Help
Discussion in 'Suspension/Chassis' started by military_hitman, Nov 16, 2008.
  1. military_hitman
    military_hitman Member
    FORT POLK, LA
    93 TOYOTA
    IS THIS THE WAY THE FRONT BAG IS SUPPOSE TO LOOK AT THE FULL UPRIGHT POSITION I DONT THINK IT DOES BUT IM NEW TO THE BAG THING[​IMG][​IMG]
  2. military_hitman
    FORT POLK, LA
    93 TOYOTA
    Sorry First Bag Pic Was Upside[​IMG] Down
  3. lownloud
    lownloud Toyotaholic
    Plains, Montana
    Hey man, that standoff plate should have a complete place for the entire bag base to mount on. That setup looks to be a accident waiting to happen with your mounting bolts and such. Try plating it and making sure the bag base mounts completely flat on the top and bottom, some roll on the bag is acceptable and is normal because unless a/the suspension your modding to moves straight up and down - you will have some roll, too much and some bags " roll over ". . .
  4. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    it looks to me like the lower bag bracket isn't bolted in the right set of holes. it should bolt on using the same holes that the strut bars use. that is the same bracket my yota had when i got it, and with a 2500# bag it set right flat on the bracket. it almost looks like thats a 2600# bag judging by how much space its taking.
  5. lownloud
    Plains, Montana
    . . . I cut that bracket off mine because I didnt like the way it looked, plus I installed the new lower bracket I got from candospecialties.com, my stock bracket was all warped and dented up, so OFF to the scrap it went . . .
  6. burnzya
    bodied 73 hilux
    i plated my lower control arm and moved the bags inward to get more lift.
  7. military_hitman
    FORT POLK, LA
    93 TOYOTA
    well thanks the guy i got the truck from didnt seem like ne new to much bout it but i wanted yalls opinion so i kno how to do it the right way ill probably go out and fix it in a lil bit thanks for the help
  8. military_hitman
    FORT POLK, LA
    93 TOYOTA
    whats the biggest bag i can put on this truck height wise in the front
  9. burnzya
    bodied 73 hilux
    most 2500 and 2600# bags are around 3" deflated. if you only have the 4 popper in the truck a 2500 is all you need. it will also hold a small block v-8, but the pressure has to be alot higher. it's pretty tight properly fitting a 2600# bag. the way i moved my bag in and kind of under the frame gives me 10" of lift, which i think is more than stock ride height.
  10. military_hitman
    FORT POLK, LA
    93 TOYOTA
    im only gettin like a 5 1/2 inch lift with mine i dont think the guy new what he was doing any suggestions
  11. burnzya
    bodied 73 hilux
