My dyno results
Discussion in 'Engine/Drivetrain' started by Kristian43, Jan 12, 2012.
  1. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Alright since i saw another dyno thread it reminded me to post up mine.
    The mods I have are:
    cold air intake with KN filter
    Tuned air fuel ratio(on the AFM)
    Advanced timing on 91 octane
    Stock supra muffler
    Removed power steering
    removed fan clutch -> electric fan
    Exedy stage 1 clutch
    Lcengineering 9lb flywhweel
    royal purple in engine, tranny, and diff
    msd coil, msd wires, ngk iridium plugs
    and other things i know im forgetting but thats most of it.
    All this added up to about 121 rwhp and 146ft-lbs of torque on a mustang dyno.
    since then ive dyno'd it again because I ported the stock afm and on that dyno run it picked up 1hp! (Free HP! :D)
    After that i got lcengineering's header! havent dyon'd it since I installed the header but will soon. Although I havent really noticed a difference since installation except it sounds better.
    BIG NEWS:
    We did a few runs using the supra afm, and later we switched back to the stock afm because the afr with the spra afm wasnt very consistent and seemed to be running rich even after we adjusted the afm to run leaner.
    The stock afm made approximately 6ft-lbs of torque more than the supra afm
    And approximately 3.5hp more than the supra afm.
    as you can see the supra afm had an inconsistent afr and the stock afm was much smoother.
    so all you guys with the supra afm :brickknock: i wasted 140 on mine :(
    Oh and if someone know how to transfer video from a droid x to my comp easily, Ill have a dyno video too!...HELP ME!
  2. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    Wow those are some nice numbers. How did you tune the AFM?
  3. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    wow, thats amazing for just bolt ons!!
  4. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Roach - i guess i should make a thread on how to do it, i could also do a video which would be waaaaaaay faster if someone could help post vids off my droid x?!
  5. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Joey - dude ive replaced and cleaned so many parts on my 22re i dont even know what i can do anymore short of taking apart the head and block...which i will do soon :D
