motor rebuild
Discussion in 'Engine/Drivetrain' started by TSLUX, Jan 12, 2010.
  1. TSLUX
    TSLUX Member
    WAIPAHU
    90 xtra cab
    i dont wanna spend too much but want it to be kinda fast at the same time.
    thinking of clean up stock motor, timing chain, valves, a cam, bigger throttle body and headers.
    would that be good or is there a bettter way.
  2. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    22re? honestly it takes allot of $ to get decent HP out of the 22re, like you said, give it a good cleaning and basic rebuild, Throw on a open air filter or complete intake, header and exhaust and call it good
  3. project_DragTruck_v2.0
    project_DragTruck_v2.0 Veteran
    In the words of an old hot rodder "Speed is money,kid. How fast do you wanna go?"
  4. JDSnake
    JDSnake Veteran
    Las Vegas
    79 longbed
    Freshing up the engine will help, but like other's said, getting power out of these engines is not easy or cheap. Just research, I did and was shocked at some of the prices.
    So you have to pretty much work w/ what you got. Like you said, i/h/e will help. Check your engine mounts, wasted power if the engine is flopping around. Find a better set of gears. A locker can't hurt either. If your manual fan go e-fan.
    Also loose some weight. It works on all the sports cars. Think Lotus. Gut everything you can stand to loose.
    Out of all that, I would pretty much say that gearing will make the most difference
  5. thundering02
    thundering02 Addict
    Fenton 63026
    250hp seems to be the max feasable with the 22r's.... now if you want anthing else I'm sure somebody here can point you in the right direction.
  6. TSLUX
    TSLUX Member
    WAIPAHU
    90 xtra cab
    yeah, my plan isnt to be the fastest pickup out there, i just want a rebuilt motor because i hit 200's but i wanna do minor things like a cam and throttle body to push it alittle more.
  7. joeynational
    PHX,AZ
    91 2WD
    what do you mean you hit 200s? 200hp? i gotta call BS on that one, sorry:D
  8. Nook
    Nook Addict
    oregon
    I think he probably means he hit 200,000 plus miles and wants to freshen the engine up.
  9. TSLUX
    TSLUX Member
    WAIPAHU
    90 xtra cab
    yeah i hit the 200,000s:verdict_in:
    if i had 200 hp i wouldnt want to rebuild that beast.
  10. project_DragTruck_v2.0
    I know of a reasonably cheap way to get well over 300Hp out of one, for a few minutes anyway....
    Slap a bottle of giggle gas on it. They'll hold up longer than you'd think! LOL!!
