More Winter Work
Discussion in 'Exterior/Body' started by TRUCK ACTION, Jan 29, 2016.
  1. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    As every winter I try to make some changes to my ride to stay competitive next show season, so on of the changes for this year is adding a aid to help level the truck when going to ride height! I incorporated two bubble levels into the forward portion of the console & back light them with a switched LED.
    Will repaint that item & reclear coat the whole console. 20160129_134831.jpg 20160129_135019.jpg 20160129_135039.jpg
  2. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    At the same time I made the shift boot base wider to hold it better!
  3. jetas
    Thats pretty fckin clever. i like it
  4. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    Nice. When I first read it, I thought u had a "brain" computer thing to figure it out for you, But then I got it once I saw the pics. simple and effective!
  5. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
    Accuair E level. Bad ass but $$$$$
  6. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I do have a Air Lift Auto Pilot, but still can be not level,uses pressure sensors no height sensors, this will just be another check!
    Air Lift is on their 3rd generation of this system,mine is the first, & no replacement ECU for mine,when & if it fails I will change to a Accuair E level, & kept my valve manifolds.
