Low engine power!!!
Discussion in 'Engine/Drivetrain' started by Yota95, Feb 1, 2018.
  1. Yota95
    Yota95 Newbie
    Safford AZ
    1995 Toyota Pickup 4x4
    I have a 1995 pickup 4x4 with a 22re. I recently swapped engines do to a split cylinder wall with a remanufactured engine from a certified engine joint. Truck has less power now then when the old engine was in and occasionally backfires through the intake. I have the smog elimination kit (not sure if the vacuum lines are hooked up right). Has anyone else encountered this problem and can anyone help please?!?!? Thank you in advance!!!
  2. jetas
    Check your timing. Thats probably going to be the issue with the backfire.
  3. Yota95
    Yota95 Newbie
    Safford AZ
    Thanks bud!!! I will check it in the morning. Any ideas on the low engine power???
  4. jetas
    Timing being off can have that effect
  5. Yota95
    Yota95 Newbie
    Safford AZ
    If the timing is good is there anything else that could cause that?
  6. jetas
    The vacuum lines could also cause problems
  7. Yota95
    Yota95 Newbie
    Safford AZ
    Y
    Oh were right with the timing bud thanks a lot man!!!
  8. jetas
    How off was it
