Is this Vacuum hose too Small?
Discussion in 'Engine/Drivetrain' started by DjMjD, Feb 22, 2013.
  1. DjMjD
    DjMjD Enthusiast
    Las Vegas, Nevada
    93 base
    I went to O'Rielly's and I brought in the measurments I needed and ended up with smaller hose. The one on the left is the original and the one on the right is the new stuff. Will this cause problems?
  2. not forgotten
    not forgotten Addict
    Washington
    82 SR5 L/B
    Thats funny, I did the same thing the other day and went to the same store. I just replaced my vaccum hose with a new one and I always take in the old one if not an example of what I need just to be safe.
    The new hose is smaller in I/D and will be tighter going on, I would put a small amount of lube, I used 3n1 oil on the outside of the vaccum tube to allow the hose to slip on there and the only air/fluid that is passing through, is going through the tube itself, so seems like a smaller tube would just be tighter to slip on, thats what the lube is for. So should not be a problem from what I know of, someone correct me if I'm wrong.
    Hope this helps
  3. not forgotten
    Washington
    82 SR5 L/B
    2nd paragraph, line 4: Thats supposed to be, seems like a smaller hose would just be tighter to slip on there.
  4. DjMjD
    DjMjD Enthusiast
    Las Vegas, Nevada
    93 base
    Thanks. I appreciate the quick reply. I am having a little trouble but not much. The original hose was slipping off way too easy and I have the same size hose but newer and it was slipping as well. I just hope that it will not mess anything up since I am trying to fix it. :)
  5. not forgotten
    Washington
    82 SR5 L/B
    That hose on the right is definitly smaller in I/D not sure why it would be slipping off the vaccum tube? What about putting a small hose clamp on there?
    Good luck
  6. AGUILAR3
    AGUILAR3 Veteran
    SoCal (626)
    dab of dish soap will get the smaller hose in without too much trouble.
  7. DjMjD
    DjMjD Enthusiast
    Las Vegas, Nevada
    93 base
    no the one one the left sorry but newer was slipping off. not easily but enough to make me worry. AGUILAR3 that bug always bugs me out. LOL
  8. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    It shouldn't cause problems and a little smaller wont hurt
  9. AGUILAR3
    AGUILAR3 Veteran
    SoCal (626)
    :waytogo:
  10. Chris D.
    Chris D. Member
    I just smacked my monitor.. :evil: seriously.. :eek:
  11. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    +1 always bring in a sample to compare.
    If the old hose is stretched and brittle (falling off) it may be that it should be smaller than it is.
    If the new one goes on without tearing, it'll be fine.
