Idle is set to high... When you step on the brake the ECU thinks your coasting to a stop and is shutting down the injectors to save gas... Lemme guess its sounds something like this.... Vrrooooom Baaaahhh Vrroooom Baaaahhh Vrroooom Baaaahhh....
^^^ this is the problem. my 4x4 did the same thing. i turned the idle down just a little and it fixed it. maybe you have a slight vacuum leak that has caused the idle to come up, and that is causing it.
i solved the problem yesterday; i left it running and placed a brick on the brake. it started doing the VROOOMMM BAHHHHHH jeje so i turn the screw on the AFM censor counter clock (the screw went up). it worked but the A/C blew warm air so i had to mess with the screw on the thr.body and like magic. hope this works to anyone with this problem....
