idle problem when ac and brake on at idle
Discussion in 'Engine/Drivetrain' started by dean248, Aug 13, 2010.
  1. dean248
    dean248 Newbie
    Maine
    94xcab 22re 4wd
    my engine has always flucuated at idle when ac is on and brake pedal is held down. when ac is turned on.idle steps up like it should,but press the brake and rpm go to low idle near stall then back to high idle then low, then high...
    Anyone ever had similar problem???(22re)
  2. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    vacume leak somewhere, or leaking booster. When you step on the brake do you hear a squish or sucking noise from the brake area under the dash?
    check you vacume hoses in the engine bay, low vacume will also cause this issue...
  3. Ea4bes
    Ea4bes Member
    so cal
    92 single cab
    yeah my truck does that too but havent really looked for the problem. but its does it some days then other days its fine.
  4. dean248
    dean248 Newbie
    Maine
    94xcab 22re 4wd
    solved
    Problem solved. I turned down the black knob on the throttle-body(the two ac vacuum lines lead to it) and that solved problem. Thanks to Nook for suggesting remedy!!!!!
  5. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    can i see a pic of the knob you are referring to? please?:waytogo:
  6. Nook
    Nook Addict
    oregon
    :waytogo: Glad you got the problem fixed.
  7. dean248
    dean248 Newbie
    Maine
    94xcab 22re 4wd
    Sorry, I don't know how to send pictures. Knob is on passenger side of throttlebody,located between the E and F embossed in cover. Slotted ,black hexagon with spring on shaft. Hope this helps......
