i need help!
Discussion in 'Engine/Drivetrain' started by LOW-YOTA, Apr 13, 2010.
  1. LOW-YOTA
    LOW-YOTA Newbie
    MANDEVILLE LA.
    1992 TOYOTA P-UP
    Does anyone know if a 22r can be ran without the wiring harness. I want to bypass everything like the old school v 8
  2. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    if you get a gm 1 wire alt, and dont mind running a wire to your ignition coil and dont want ac ya it can be ran without that harness. you will need to swap out the crap toyota carb for a weber, which will also take out a bunch of vacume lines and junk. im doing it right now, cept i have the stock alt with the external regulator on my 73. you will need to run a few wires like you do on the old v8's eg. starter, and power wires for your fuse block, but other then that ya pretty simple.
  3. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    if you unplug the carb harness it wont run...... mostly due to the choke. but if you get a better carb as dillin mentioned yea, you can rid yourself of the harness. make sure to still run a temp gauge wire to a sensor though so you can keep an eye on your motor. either or install a mech gauge. :waytogo:
  4. 22r
    22r Veteran
    Maui
    what if i removed the choke assembly from the stock carb do i still need it plugged in?
