How come my clear corner lights dont fit right. Like they dont go into the 2 holes in the end of the grill. You cant really see it much in this pic. But i had to change a light on the passenger side and the light doesnt even twist into the hole. I kinda ***** rigged it to keep the light in. But now it comes loose every couple days. I guess it isnt a real huge issue since ill be getting 4x4 fenders but still its annoying.
Did you get into a front end collision? If not it's most likely because those lights are aftermarket ones. I've had parts from Taiwan that fit and don't.
two things, like he said probley not oem, are your fenders after market? then you said your getting 4wd fenders ill take those corners ill make them work
i have the same problem with mine. the driver side fender was replaced years ago and since i've had the truck, i couldn't manage to get the gap perfect but as of now, it's only about 3/4-1cm. annoying yes, unfortunate, yes.
