Hood cave-in?
Discussion in 'Exterior/Body' started by 88Sandshark, Oct 5, 2009.
  1. 88Sandshark
    88Sandshark Toyotaholic
    Lake Elsinore, CA
    Am I the only one or has anyone else's hood caved in in the rear? Now I have to yank on the front to open the hood. I don't know what happened... i worked on the truck one day and the next the hood's smashed in the rear? I don't remember pissing anyone off...:shrug:
    Here's what I had to work on, and it only squeaked for two days!
  2. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    loosen the 4 bolts that hold the hood on, and pull the hood forward just a lil bit and re-tighten
  3. IronNam
    12mm socket is all you need :D
  4. 88Sandshark
    Lake Elsinore, CA
    I moved it forward all the way and still no difference. I know this hood's a goner. I wanted to replace it anyway... it never sat right. Don't buy aftermarket unless you absolutely have to... I should have told that to my grandfather when this was his...
  5. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    take the hood off and lay it on the grass, top down.
    take a ruber mallet and whack it good right where its hitting. then whack it not so good, right next to there, and again, and again. keep tapering out a bit.
    this works great on my wheeler, but i dont care how it looks, hood has been on 3 cabs...
    you might also try loosening the brackets that hold the hood hinges and moving them up.
