high idle
Discussion in 'Engine/Drivetrain' started by low_toyota92, Dec 26, 2011.
  1. low_toyota92
    low_toyota92 Enthusiast
    Nashville, N.C.
    92 ex cab
    so i just bought a new beater.... its an 89 yota with an 22re automatic.. the problem is after you drive it for a few miles then put it in park it idles up to bout 2500rpms... and never really idles down.. any suggestions guys?
  2. planemos
    planemos Toyotaholic
    British Columbia
    Check for vacuum leakes. I googled it briefly and I suggest that it has something to do with the egr.
  3. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    stuck idle control motor... its located under the throttle body
  4. whysmee
    whysmee Enthusiast
    62 toyopet and 76 toyota stout
    the 22R was not a real common motor here as most 4th generation petrol "gas" hilux had a 3Y or 4Y in australia, gen 3's had 18R's and gen 1 and 2 had 12R's.
    the 5th generation here had a 22R non EFI, on the earlier models the throttle advance on the electronic choke sticks and here most just disconnect it and at times remove the electric choke altogether.
    Toyota Hilux - Wikipedia, the free encyclopedia
  5. low_toyota92
    Nashville, N.C.
    92 ex cab
    thanks guys.. gives me some where to start ill let ya know what it was when i figure it out..
  6. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Its called the idle air control valve, located underneath the throttle body, the same thing happened to me, there's no way to fix it the only thing you can do is get a new one, it's an expensive part so your best bet is to find it at a junk yard
  7. low_toyota92
    Nashville, N.C.
    92 ex cab
    thanks man... until i get time to fix it does it cause any problems to wait a lil while?
  8. low_toyota92
    Nashville, N.C.
    92 ex cab
    so i finally had time to mess around on my truck today, but i dont know what this iacv looks like.. could someone post a pic of it and its location... thanks
  9. TDS909
    TDS909 Veteran
    ONTARIO
    1992 st cab
    isc valve
    It's under the throttle body, can't miss it, Did mine awhile back
  10. low_toyota92
    Nashville, N.C.
    92 ex cab
    ok, so i feel like an idiot... what th prob was, was th spring on th throttle cable and throttle body is was weak, i wound it a loop tighter and now perfect idle.... damn...
  11. low_toyota92
    Nashville, N.C.
    92 ex cab
    it wouldnt pull th cable all th way
  12. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    At least yuu didn't spend money and time on a part you didnt need
  13. low_toyota92
    Nashville, N.C.
    92 ex cab
    true story man, but still feel like an idiot.. haha
