HID Problem
Discussion in 'Interior/Electronics' started by Humbol, Jun 28, 2013.
  1. Humbol
    Humbol Member
    Maui, Hawaii
    89 toyota pickup single cab
    so today, i turned on my headlights. One headlight HIDS work, but the other headlight didnt. so i switched to high beam. Now the headlight that the HID was working, Hi beam didnt work for that headlight but the other headlight that the other hid wasnt work, the hi beams worked. any solution? :brickknock::brickknock::brickknock::brickknock::brickknock::brickknock:
  2. macawilial
    macawilial Veteran
    Born and raised in San Diego
    Try this
    Try swapping over the ballasts with each other and see if the problem follows. Good luck
  3. Humbol
    Humbol Member
    Maui, Hawaii
    switched ballast, but the hi beam lights are still a problem. but the Hids worked when i switched ballast to the other headlight. so im guessting it must be the ballast? but how to fix hi beams?
  4. macawilial
    macawilial Veteran
    Which type do you have?
    Does your high beams have HID bulbs acting as high beams or are they the solenoid flipper type?
    How about you explain which type of HID system you have, then we can go from there
  5. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    I had high low kit used a non hid h3 bulb ...what a joke Had to switch my connections around to get the hid to come on ....the h3 bulb was so close to the hid bulb any extended high beam use would melt the hid bulb so said F it no high beam
    If this is the type kit you have don't use the high beam the h3 bulb is useless as a high beam and puts off a ton of heat will pop your hid bulb
