Help with dings
Discussion in 'Exterior/Body' started by jrknsrk08, Feb 13, 2009.
  1. jrknsrk08
    jrknsrk08 Member
    Sierra Madre, CA
    88 single cab 2wd
    I wanted to know if the best way to get rid of dings that can not be pulled out is to 'BONDO'? I was also curious on how to 'shave' certain parts. Will 16 gauge do or do you just 'bondo' that as well? Thanks for your time.
  2. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    i use a stud gun so all dents and dings are pullable. i have a hand attachment for pulling the little dings. 16 gauge will be fine since most body panels are around 18ga. for things like handles and big items you need to weld in a filler, then fill. weld slowly to avoid warping, and to reduce the amount of filler needed.
