HELP!!!! Rotor won't turn on drop spindles!!
Discussion in 'Suspension/Chassis' started by mprtftr, Jan 13, 2013.
  1. mprtftr
    mprtftr Enthusiast
    Central VA
    94 Reg Cab
    Okay, I FINALLY got the drop spindles installed (Chassis Tech).:clapping: Then, as I'm about to put the rotors back on my friend says "Why don't you go ahead and change the outer wheel bearings? That one looks like it has a little gap starting." :doah: So no problem, go to the parts store and get some new ones. Packed them and bolted everything back together.
    Here's where the problem comes in...'
    Once everything is back together, I give the rotor a couple turns to see how smooth everything is, and the damn thing is rubbing on the backing plate. Bend that out of the way and try again. No problem but now the rotor WON'T turn.:shrug: Loosened the spindle nut, no better.
    Took everything loose and took off the backing plate and re-assembled...still no turn. I'm at my wits end. Has anyone ever had this problem before and if so, what did you do to fix the issue?
  2. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Do you have the washer that goes between the outer bearing and wheel nut ?
  3. mprtftr
    mprtftr Enthusiast
    Central VA
    94 Reg Cab
    Yeah, and it's seated in the key slot.
  4. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Hmm possible bearing thickness difference haven't ran into this compare the two?
  5. mprtftr
    mprtftr Enthusiast
    Central VA
    94 Reg Cab
    New bearings are slightly thicker. (Will have to take those back.) Put one of the old bearings back in and put it all back together but, I still have the same problem.
  6. TDS909
    TDS909 Veteran
    ONTARIO
    1992 st cab
    If you over tighten the axle nut the rotor wont spin,Snug the axle nut then back it off half a turn, Hope this work's
  7. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    Yeah u don't tighten those. Just snug them and put ur cotter pin in
  8. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Hope he new not to over tighten the spindle nut .kinda a givin there
  9. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    When ever i put new set of packed barrings in i tighten then a fair amonte guess about 30 foots pound then back the nut off fully tap rotor with rubber mallet or bump it with your palm then spin it. then tighten tell nice and snug then slip in the cotter pin
    reason for this to seat the barrings
