HELP!!! None of my gauges work
Discussion in 'Interior/Electronics' started by Carnie, May 2, 2011.
  1. Carnie
    Carnie Newbie
    United States
    '92 single cab SB
    Hellp, I am brand new to this forum and also brand new to owning a Toyota. I just bought a 1992 Toyota Hilux. However, there is a quite a bit wrong with it and I need a little help.
    None of the gauges work (Fuel, Temperature, Speedometer) nor does the Odometer. I was curious as to if someone could give me a list of possible diagnosis. I also seem to have a small leak coming from my fuel tank, however, I think it may just be because I filled it all the way up and it is overflow.
    I am not real handy when it comes to vehicles but I am looking to learn. I am hoping that this forum is the place to help me.
    THANKS!!
  2. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    fuel tank shouldn't leak at all. any overflow will come out the gas filler hole in the side of the bed.
    Check all the fuses to start with. After that would be the wiring (power and ground) to the cluster. if that's ok, then it's the cluster itself. Could also be more than one :(
