I'm in the process of swapping a W55 transmission into my 74' Hilux and in order to keep the stock shift lever position, I need the shorter housing that bolts to the selector rod. These are long discontinued and finding one is impossible. If anyone knows where to find one, it would be greatly appreciated. Here is a diagram:
If you cant find it at a dealership then youll most likely need to find a tranny at the JY to pull what you need
I don't even see anything numbered 33502-14100 The item that positions the shifter is 33521 Housing that slides on 33251 Lever It determines where the sifter will sit. When I swapped a W58 for my W55 I used the one out of my W55
